Chris39 Posted June 10, 2019 Report Posted June 10, 2019 I have a three storey guest house which has 7 guest rooms which has a fire escape and each floor is a fire compartment, but all the neighbouring guest houses do not have fire escapes just internal compartments just curious as to how that would work for them in the event of a fire it just doesn’t seem safe, could you please help me understand the legality of this ? Quote
Tom Sutton Posted June 10, 2019 Report Posted June 10, 2019 It all depends on the fire risk assessment theirs with yours, as required by The Regulatory Reform (Fire Safety) Order 2005 you would need to compare them, the guidance for B&B premises is Sleeping accommodation. Also check out Do You Have Paying Guests . Quote
Chris39 Posted June 11, 2019 Author Report Posted June 11, 2019 17 hours ago, Tom Sutton said: It all depends on the fire risk assessment theirs with yours, as required by The Regulatory Reform (Fire Safety) Order 2005 you would need to compare them, the guidance for B&B premises is Sleeping accommodation. Also check out Do You Have Paying Guests . Thank you Tom appreciate your advice Quote
