Gillian Posted March 9, 2019 Report Posted March 9, 2019 Re converted house over 3 floors with communal hallway 3 flats we are installing smoke alarms hard wired behind all flat doors should they be interlinked? also installing Heat Detectors in 3 kitchens = Not interlinked is this correct please It is quite daunting the varying advice given thank you Gillian Quote
AnthonyB Posted March 10, 2019 Report Posted March 10, 2019 This is the guide that you should use to determine what you need https://www.rla.org.uk/docs/LACORSFSguideApril62009.PDF Quote
TJ Tyrie Posted May 28, 2019 Report Posted May 28, 2019 Your local authorities Building Control Officer (BCO) may be able to assist you with guidance. Quote
