Joanne b Posted February 9, 2019 Report Posted February 9, 2019 Hi,Thanks all for reading this post.We've just had a loft extension completed in our house along with some internal renovation work which has opened up the ground floor. The building control officer who visited this week wasn't sure whether the fire rated pocket door we have (identified by the large red arrow on the attached plan) separating the kitchen and living room from the rest of the house will suffice to meet the Approved Document B regulations, with regard to the escape route from the 1st floor and loft. He said he'd look into it and let us know next week. I've read through other posts on the forum, along with the AD B and I'm still not clear. I therefore hoped to call upon the wisdom of those of you here who might be good enough to offer your advice, based on your knowledge of such matters. Thanks again. Quote
Tom Sutton Posted February 9, 2019 Report Posted February 9, 2019 I cannot make sense of the drawing, you need a proper architects drawing with measurements and what is half hour fire resistant. Quote
Joanne b Posted February 10, 2019 Author Report Posted February 10, 2019 20 hours ago, Tom Sutton said: I cannot make sense of the drawing, you need a proper architects drawing with measurements and what is half hour fire resistant. The pocket door identified by the red arrow is 30mins fire resistant Tom, along with the entire wall which protects the staircase from the first to the ground floor, meaning that this staircase isn't open to the ground floor. Hopefully that helps. Quote
Tom Sutton Posted February 13, 2019 Report Posted February 13, 2019 It looks like the staircase is open to the dining room which would not be acceptable, again a proper drawing is required and I would not try to give any suggestions without it. Quote
