Steveo Posted November 16, 2018 Report Posted November 16, 2018 Hello all, Could someone tell me if there is a stipulated number from when a guest house is deemed to be a hotel, I’m thinking in terms of the required fire alarm needed, when say a simple guest house with no more than 3 floors, it would be acceptable to have a grade D or even grade F but at what number of rooms would you need a more sophisticated system with call points etc.? Thanks for any advice. Quote
AnthonyB Posted November 16, 2018 Report Posted November 16, 2018 There is no fixed definition, there is some basic pointers to help you decide in here:https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/11085/payingguests.pdf If you feel you are bigger than the property types detailed in the above you need to use this guidance: https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/422192/9281_Sleeping_Accomodation_v2.pdf Quote
