Jsholl Posted August 9, 2018 Report Posted August 9, 2018 Our CO dector went off then stopped, when I got to it showed 0. I hit the reset it blinked, read gas 227 then 888 now reads 0 and hasnt gone off since. We had a new gas dryer installed sbout 4 hours prior. Should i be concerned, are we ok? Quote
Safelincs Posted August 9, 2018 Report Posted August 9, 2018 Hi If this carbon monoxide alarm is a Fireangel CO9D alarm with digital display, it records peak carbon monoxide (also shortened to 'CO') levels which can be queried by pressing the Test button. It displays the highest recording and then resets itself. Your alarm is telling you that it recorded 227ppm which is high. I would avoid using the gas dryer until you have found out whether it is leaking any CO gas into the building. Harry Quote
