Guest LizKLen
I recently stayed in a holiday cottage in Scotland, could you tell me if Holiday lets are included in premises that are subject to a Fire Safety Order?
  • 2 years later...
Dear Sir
I am a landlord managing a number of commercial/ residential properties.
I want ensure I comply with the law in all properties.
Can I be my own Responsible Person or do I have to engage professionals.
If professionals what qualification should they have?
As an RP you can conduct a fire risk assessment and you are responsible for it no matter who does it. However I would suggest you only consider small uncomplicated premises and use the free guides available from the DCLG. Check out http://www.firesafe.org.uk/regulatory-reform-fire-safety-order-2005/ and http://www.firesafe.org.uk/fire-risk-assessment/ also http://www.firesafe.org.uk.
There are two publications to assist you in selection a competent person they are A Guide to Choosing a Competent Fire Risk Assessor and Competency Criteria for Fire Risk Assessors.
Check out http://www.fia.uk.com/en/info/document_summary.cfm/docid/E6479C4F-E267-4DD4-8B55A6930C685F13 and http://www.fia.uk.com/en/Information/Details/index.cfm/FRA%20Competency%20Criteria
When you ask a question you need to to be precise when describing the premises. Ben above states "commercial/ residential properties" what does this mean, offices, shops, factories, workshops, flats, houses, holiday lets because to decide if they apply to The Regulatory Reform (Fire Safety) Order 2005 you need a full description also helps in deciding who the Responsible Person (RP) is.
