Paul36 Posted May 4, 2018 Report Share Posted May 4, 2018 Hi All, I am fire risk assessor looking to get hold of a Q key for dry riser outlets . Does anyone know where i can get one?. Regards, Paul Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted May 4, 2018 Report Share Posted May 4, 2018 Firstly what is a Q key for dry riser outlets I though they just used standard yale rim locks. You could check out https://www.easylocks.co.uk/fb-fire-brigade-keys and see if they can help. Quote Link to comment Share on other sites More sharing options...
Guest Meg26 Posted November 25, 2018 Report Share Posted November 25, 2018 Paul36, I have the same thing marked on the dry riser inlet at work. Did you have any luck finding a Q key? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted November 26, 2018 Report Share Posted November 26, 2018 Ankerslot & BiLock produce a lock called a Q-Lock which is a rim lock but why they would wish to use it on dry riser is anybody's guess. They use magnetic keys and cannot be copied. check out https://www.facebook.com/QLocks/ Quote Link to comment Share on other sites More sharing options...
Guest Dan@m-fire Posted June 7, 2019 Report Share Posted June 7, 2019 I know exactly what you mean. Dry riser Q key. I have a couple of spares in our appliance. Quote Link to comment Share on other sites More sharing options...
Crusher Posted June 13, 2019 Report Share Posted June 13, 2019 This topic interests me. In my experience the best locking mechanism for riser boxes is the budget lock. From a fire service perspective (and in the absence of a 'master key') the budget lock allows any fire station to respond to any premises and access the firefighting riser. It is not particularly resilient to supply the nearest two stations with keys. They may all be out at incidents. Despite not being with the fire service any longer, it still irks me that riser boxes are supplied with Yale type keys on nearly every occasion. Is the Q key system adopted by the riser box manufacturers and installers? It could be that I am missing a trick and that all riser boxes are 'keyed alike'. I'd be grateful to hear if anyone has further information on the matter. Thank you Quote Link to comment Share on other sites More sharing options...
Guest Kev Posted June 15, 2021 Report Share Posted June 15, 2021 The Q-key for dry risers is called Queen key, Also there are 3 different keys for cabinet boxes and they all look very similar to each other. Quote Link to comment Share on other sites More sharing options...
Guest Martin Fire and Light Posted June 21, 2021 Report Share Posted June 21, 2021 Hi, Does anyone know where i can get the queen keys as none of the cabinet manufacturers have a clue ?? cheers Martin 07970165433 Quote Link to comment Share on other sites More sharing options...
green-foam Posted June 24, 2021 Report Share Posted June 24, 2021 I googled, and as far as I can find they are no longer installed, instead locks that the fire brigade may need access to use one of 6 keys, the set is called a "fire Brigade set" "Set of six Fire Brigade keys. Used by emergency services, councils and other authorised bodies. Comprising FB1, FB2 & FB4 for mortice deadlock and rim lock keys and FB1/FB5, FB11 & FB14 pipe keys for Fire Brigade padlocks." Quote Link to comment Share on other sites More sharing options...
AnthonyB Posted June 24, 2021 Report Share Posted June 24, 2021 The FB range consists of only mortice and padlock keys and a drop key - that sellers description is misleading as it's not for the 'Yale' style of Spring cylinder lock used in most dry risers, but a rim lock taking a mortice style key. Best bet is asking whoever tests your dry riser as they will need the keys to do so, last resort is a lock smith Quote Link to comment Share on other sites More sharing options...
