Guest KevinB Posted April 28, 2018 Report Posted April 28, 2018 Hi, Is it possible to have a step at the final exit door from a protected stairwell. WE have app 180mm difference between the inside FFL and the external pavement. Is it permissible to incorporate a step at the door and where would we find guidance on this? Thank you. Quote
Tom Sutton Posted April 28, 2018 Report Posted April 28, 2018 You will find guidance in approved document M and K and have you considered wheelchair uses, also risers have a maximum height of 150mm. Check out https://www.gov.uk/government/collections/approved-documents https://www.planningni.gov.uk/index/policy/supplementary_guidance/dcans/dcan11_draft/dcan11_draft_design/dcan11_draft_accessb.htm Quote
