Tony Campbell Posted April 13, 2018 Report Posted April 13, 2018 Thank you for reading this message. Could anybody direct me to where I can find out more information/regulations on the force required to open a final exit/fire escape door on a block of flats. The doors present require significant force to open, and I am concerned that a disabled or elderly person would not be able to open them. Thanking you Tony Campbell Quote
Tom Sutton Posted April 14, 2018 Report Posted April 14, 2018 BS EN 1125:2008 Building hardware. Panic exit devices operated by a horizontal bar, for use on escape routes, is the standard for final exit doors that use panic bars. BS EN 179:2008 Building hardware. Emergency exit devices operated by a lever handle or push pad, for use on escape routes. Is the standard for lever handle or push pads. You should find the release forces recommended for each device, so it depends how the exit door is secured. Quote
Guest Thanking you. Posted April 24, 2018 Report Posted April 24, 2018 Thank you Tom for your reply, please excuse my delay in replying. Best wishes Tony Campbell Quote
