Guest Arclight Posted April 8, 2018 Report Posted April 8, 2018 I've recently been working on some holiday flats and had a 'disagreement' with the owner about and alteration he made. The building consists of four separately let bedrooms on the second floor, a kitchen, bathroom and dining room on the first floor, and a commercial property on the ground floor. There is only one escape route from the upper floors, a single internal staircase. The owner decided to remove the wall between the stairs and dining room, to make it "feel more open". My understanding was that it needs to have a fire wall, as it should be a protected staircase. His justification was that a dining room doesn't count as a living area, and therefore doesn't need to be seperated from the stairs. Have I got the wrong end of the stick here? Quote
Tom Sutton Posted April 10, 2018 Report Posted April 10, 2018 You are right a dining room is a habitable room and create a possible fire risk consequently the staircase has to be protected from it. Quote
Guest Arclight Posted April 12, 2018 Report Posted April 12, 2018 I forgot to add that the dining area also contains the consumer unit for the building. The problem is he's the one doing the fire risk assessment. Who should I contact to get this sorted? It's multiple holiday lets, does it fall under HMO? Quote
Tom Sutton Posted April 12, 2018 Report Posted April 12, 2018 It is unlikely to be a HMO but subject to The Regulatory Reform (Fire Safety) Order 2005 especially as a FRA is involved and the enforcing authority is the local fire and rescue service, contact them. Quote
