Ei141 beeping
Guest Kevin Martin
Hi I have 2 Ei141 smoke detectors one of which today started beeping continually and the test button does seem to work.
Green Light NO
red light not on or flashing
New battery fitted about 12 months ago
end of life of unit 2021
can you advise what the problem could be?
Hi Kevin
With the green light off, your power supply to the unit is off and the battery is being drained. Check that the fuse has not been switched off. If that does not resolve things you will need to get an electrician out to check your wiring and connections.
Harry
