Guest Lawrie Hutchison Posted March 30, 2018 Report Posted March 30, 2018 Can cold smoke seals- brushes- be fixed to both the door and the frame on the same door. have tried this but the brushes grip each other and make the door difficult to open. should seals be fitted to the door only. Do the regulations prevent fitting of brushes and strips to the frame. Quote
Tom Sutton Posted March 31, 2018 Report Posted March 31, 2018 No cold smoke seals- brushes cannot be fixed to both the door and the frame it will depend on which combination you use whether they are fitted to the door leaf or frame, check out https://www.asdma.com/knowledge-centre/ and download ASDMA Best Practice Guide and study sections 13/14. Quote
AnthonyB Posted March 31, 2018 Report Posted March 31, 2018 If retrofitting the preference is usually to fit to the frame rather than taking material out of the door. Quote
