Guest Oliver Posted March 28, 2018 Report Posted March 28, 2018 Hi, im doing a fire alarm on a social club, not too sure whats the best detection for a hall that could potentially be using smoke machines. Im planning on using an Zeta ID2 system. Thanks Quote
Tom Sutton Posted March 29, 2018 Report Posted March 29, 2018 Check out https://www.safelincs-forum.co.uk/topic/915-smoke-alarms-and-disco-smoke-machines/ but if solutions can on Zeta ID2 i do not know. Quote
AnthonyB Posted March 29, 2018 Report Posted March 29, 2018 The panel you refer to is a hybrid conventional/addressable that is in essence a 2 wire conventional that can have it's devices addressed for identification but is still using conventional yes/no detection devices rather than addressable devices that are polled and report analogue values to the panel and has limited cause and effect beyond a verification setting for HMO use (like the rafiki/fike Checkpoint Plus), so you are looking at heat detectors (I'd suspect the Opto-heats still have a risk of triggering. You can isolate devices and zones, but this has to be done via the panel (unlike addressable systems where a key switch can be programmed to do this) Fully addressable systems are often used where stage effects and smoke are present with a 'performance mode' C&E (often controlled by a key switch) that puts the auditorium multi-sensors into heat only mode during the event and then the system is switched back to normal (smoke or smoke/heat) for the rest of the time. The odd individual rouge fire officer aside this is usually accepted as the auditorium has more than enough people (including staff) to detect a fire promptly during performances. Similar setups can be used in clubs. Quote
