Recommended frequency of mains wired smoke detection in communal areas of residential block
Hi All
I have a question for which I am nearly sure of but here goes.
What is the recommended frequency of mains wired smoke detection in communal areas of residential blocks (without alarm panel etc etc) I am sure that they are also recommended to have some sort of maintenance program  i.e visual checks, pushing the test button, but is there a requirement to actually annually check them?
The linked page only covers commercial fire alarms - you appear to have Grade D residential smoke alarms installed (Which aren't required in the first place, if communal warning was needed a commercial system would be used) for which the only test regime (BS5839-6) is weekly testing using the test button and periodic cleaning of the detectors as per manufacturer's instructions (usually 6 monthly)
