February 2, 20188 yr comment_11438 I just need some clarification upon protecting stairwells in a hotel building using the example below. Building 4 Storeys. Age 1950's approx. Ground Floor - Bar and Restaurant First Floor - Guest Sleeping Accommodation Second Floor - Guest Sleeping Accommodation Third Floor - Guest Sleeping Accommodation The building has 2 stairwells one from the third floor to a final exit on the ground floor and one from the second floor landing to ground floor via an alternative final exit. (Travel distances are within GM guidelines) Question 1 - I am sure all stairwells in sleeping accommodation should always be a fire resistant for a minimum of 30 minutes. Is this correct? if so are there any exceptions? what documents can help clarify this? Question 2 - A follow up to this is would the same apply in an office building with no sleeping? Any response is appreciated. Report
