Guest guest Posted January 19, 2018 Report Posted January 19, 2018 What is the best detection system for a coffee shop downstairs ( no cooking facilities ) and living accommodation upstairs ? I am thinking L2 for the early warning for both parties ? its in renovation at the moment . Quote
AnthonyB Posted January 19, 2018 Report Posted January 19, 2018 Separate access to the accommodation or accessed via the actual shop as integral accommodation? If the latter I'd go along with your thoughts. If it's separate then there are other configurations that may suit better based on construction & layout. Quote
Guest Guest Posted January 21, 2018 Report Posted January 21, 2018 Just found out they are separate with no access from one to the other ! Quote
AnthonyB Posted January 22, 2018 Report Posted January 22, 2018 Then the only requirement for fire warning that covered both would be if the structural fire separation between the shop & flats is inadequate. Quote
