Need advise on this guys, one of my clients are a small business and are based in a old school building. There is a boiler and server unit situated in a large store room with extensive fire loading. Im not talking about the fire loading here  but the boiler is fixed to the wall. It is regularly serviced and secure but should this be in a room on its own which is fire protected? Also ref the server, it has a door missing and is very dusty inside, your opinion on that please?
The boiler will be an ignition  risk and if it can ignite material close by then you need to put control measures in place. The server will be vital to the business and should be protected for the sake of business continuity.
If it is well serviced it would be normal but if it is the damage by a fire it could lose data which could be vital to the owner and could be catastrophic.
