Guest Leigh ann Posted December 11, 2017 Report Posted December 11, 2017 Im putting a wall up to keeep the heat in my livingroom do i need a fore door and frame also does the the plasterboard need to be fire resistant thanks Quote
AnthonyB Posted December 12, 2017 Report Posted December 12, 2017 You are likely to require Building Control approval depending on a couple of factors - that process will answer your query specific to your house: https://www.labc.co.uk/your-project/homeowners/building-control-internal-alterations#buildingremoving Quote
