Guest Tom Posted November 8, 2017 Report Posted November 8, 2017 I have a quick question I hope you can help me with. I live in small former hotel turned into 6 flats over 3 floors, 2 each floor inc ground. There is only 1 exit, the front door. Its got 2 panels in the bottom, and 2 glass panes in the top. We have recently been told it must be closed at all times because "its a fire door", it has no markings as such, opens outwards, and for all intent and purposes its a standard, quite old, front door used on a communal building (you wouldnt use it on a house). Legally Im not sure you "must" keep external doors closed. I also do not believe this is an actual fire door so cant be labelled as even if legally it must be kept closed. I was wondering if you could shed any light on this please as Im concerned about mislabeling, and so false sense of security and I dont really believe they are right in any case. Thanks in advance for your time and help. Quote
Tom Sutton Posted November 9, 2017 Report Posted November 9, 2017 The external door leading to fresh air is known as a final exit door and does not require to be a fire door or kept shut other than for security reasons, except when it opens onto an escape route where it could jeopardise people getting to a place of ultimate safety, like an external staircase. This would not apply in your building because there is only one final exit. Quote
