Tara Posted October 20, 2017 Report Posted October 20, 2017 I am currently refurbishing a shop unit. I have a set of worn out aluminium double fire doors and would like to change them to a single fire door minimum width 750mm. Is this ok ? Quote
Tom Sutton Posted October 25, 2017 Report Posted October 25, 2017 It all depends on the layout and if the maximum numbers who are likely to use the door is less than 60, it would be acceptable. Quote
