September 2, 20179 yr comment_10725 Hi, My Ei 151TL alarm required replacing as the 10 year date came to an end. I bought the alternative alarm as the Ei 151TL is no longer avaliable. I can see the new alarm Ei161e the wires have to be disconnected from the plug socket and re-wired directly into the alarm base. The four wires currently coming though the celing are live, battery, interconnect & neutral. My only question is what do i do with the battery wire for the new alarm Ei161e? As the Ei161e only has live, interconnect & neutral. Rob Report
February 15, 20188 yr comment_11552 I have the exact same problem - have you reached a solution yet? Report
February 19, 20188 yr comment_11569 Hi Nathan The two blue were the following: -neutral -battery The two blue wires are joined together and become the neutral. Harry Report
December 7, 20187 yr comment_13110 So what your saying is both blue wires go into the neutral on the base? Report
June 6, 20197 yr comment_14341 Connected the blues together and all is well and functioning correctly. Regards GB Report
February 19, 20215 yr comment_19345 I'm also interested in if this is the same for the Ei3016... Report
October 24, 20223 yr comment_30584 Yup...two blues in one terminal works. Same question / doubts - thanks for the answer / assurance. AICO should consider providing this info as they are selling this as a replacement. Report
