Guest James Posted August 13, 2017 Report Posted August 13, 2017 Afternoon I understand that it depends on the job time taken to plane etc but what price range should you be getting quoted for the design of a new fire alarm system etc Lets just say in my case a medium 2 floor office. If anyone does designs who can advise what I roughly should be getting quoted it would be appreciated (design only not inc equipment). James Quote
Tom Sutton Posted August 15, 2017 Report Posted August 15, 2017 You need to get together with the fire risk assessor and a fire alarm designer to design the system you require for example what categories do you require. Do you require only a manual system (M) or combined with life system (L) or including a property protection system (P) to costs will vary considerably. For example Offices: 3 Floored Victorian Building 12 x Optical Smoke Detectors 2 x Heat Detectors 7 x Manual Call Points 5 x Sounders Alarm System Used: Apollo non addressable Supplied, fitted, commissioned and certificated £4644 plus Vat Once you you know what is required then you can get some estimates. Quote
