Guest Mr Cuong Posted August 11, 2017 Report Posted August 11, 2017 Dear all. I have a error with Kidde AEGIS Single Hazard Agent Releasing Panel. 120/240 V, 50/60 Hz AC Input. With 7 Initiating, 3 Notification, 2 Release Circuits & 4 Relays in Red Enclosure (84-732001-001). This is Primary PSU Output Voltage. I replace the power supply and battery, check Voltage Input is 230V and Output 24V. I think everything is correct. But when i press system reset, the light of PSU TBL are still on. Plese tell me why and how to fix this. Thanks so much. Quote
Tom Sutton Posted August 15, 2017 Report Posted August 15, 2017 Check out http://psfirefighter.proboards.com/thread/112/fixed-extinguishing-systems?page=1 they may be able to help. Quote
Tom Sutton Posted August 15, 2017 Report Posted August 15, 2017 Also check out http://firealarmengineers.com/1 they may be able to help. Quote
