Guest Bot Posted August 8, 2017 Report Share Posted August 8, 2017 Hi is there a requirement for a Dry riser to be padlocked and strapped shut, I was under the impression that since 2015 this isn't the case??? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted August 10, 2017 Report Share Posted August 10, 2017 My interpretation is that there is is no change and a padlock and strap applies to isolation valves on wet risers for maintenance, obviously not required on dry risers. Some fire and rescue services permit the use of secured solid fronted boxes (to BS) to prevent theft of outlet valves or inlet collection boxes, if required, on both systems. Quote Link to comment Share on other sites More sharing options...
Guest Bot Posted August 13, 2017 Report Share Posted August 13, 2017 Hi thanks for this info is there any regulations to back this info up please Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted August 14, 2017 Report Share Posted August 14, 2017 BS 9990:2015 Non automatic fire-fighting systems in buildings. Quote Link to comment Share on other sites More sharing options...
