Dry riser to be padlocked?
Guest Bot
My interpretation is that there is is no change and a padlock and strap applies to isolation valves on wet risers for maintenance, obviously not required on dry risers. Some fire and rescue services permit the use of secured solid fronted boxes (to BS)  to prevent theft of outlet valves or inlet collection boxes, if required, on both systems.
