August 8, 20179 yr comment_10632 Hi is there a requirement for a Dry riser to be padlocked and strapped shut, I was under the impression that since 2015 this isn't the case??? Report
August 10, 20179 yr comment_10638 My interpretation is that there is is no change and a padlock and strap applies to isolation valves on wet risers for maintenance, obviously not required on dry risers. Some fire and rescue services permit the use of secured solid fronted boxes (to BS) to prevent theft of outlet valves or inlet collection boxes, if required, on both systems. Report
August 13, 20179 yr comment_10653 Hi thanks for this info is there any regulations to back this info up please Report
August 14, 20179 yr comment_10663 BS 9990:2015 Non automatic fire-fighting systems in buildings. Report
