Guest Meg Posted August 5, 2017 Report Posted August 5, 2017 Can you tell me how cushion pad manufacturers make synthetic cushion pads and fire safe. If the filling is polyester is the material pre treated before being made up into the cushion or is it treated after being made up. If I wash cushion pads , will the fire retardant effect be lost? Quote
green-foam Posted August 6, 2017 Report Posted August 6, 2017 That would be up to the manufacturer how they make their products "fire safe" To find the definitive answer it would be best to ask them, any thing else is only a guess. Regarding washing them, again it depends on what the manufacturer used, you may find the following article of use CLICK HERE Quote
