Guest Susan
Checking all the fire doors throughout our building some have screws missing, do we need fire rated screws as well as hinges?
Generally you should use the screws that are supplied with the fire rated hinges. Some timber fire door cores. though, such as Graduated Density Chipboard require larger screws. Consult a fire door inspector if you are unsure.
