king789 Posted July 14, 2017 Report Posted July 14, 2017 Anyone running the DCLG procedure for cladding sampling and has any advice? I'm not sure what to advise our management team and clients regarding how and what to cover the area with. We manage private residential blocks so are not directly under the same umbrella as social housing authorities. Our plan is to use abseiling teams to remove the required samples (above 18m and below 18m) from non-visible areas of the building so as to minimise the aesthetic damage. We currently do not have a solution for covering the area where the cladding would be removed from. Quote
Tom Sutton Posted July 15, 2017 Report Posted July 15, 2017 Check out https://www.gov.uk/government/news/expert-panel-recommends-further-tests-on-cladding-and-insulation and contact the DCLG who should be able to help. Quote
