Guest DavinaTa Posted June 19, 2017 Report Posted June 19, 2017 I already have a powder extinguisher but reading this site has me worried it is not the right one for multipurpose use Please advise As I'm 76 is a 2kl enough for quick use while waiting for the fire department Quote
Shawn Bosworth Posted June 19, 2017 Report Posted June 19, 2017 Hi DavinaTa The main reasons that powder extinguishers are no longer recommended is that they reduce visibility and can affect your breathing. Whenever I talk baout powder extinguishers i liken it to exploding 2kg of talcum powder in a room and then trying to find your way out. It gets in your eyes, mouth, nose and will never be fully cleaned up. The latest 'one-for-all' type of extinguisher is the dry water mist fire extinguisher http://www.safelincs.co.uk/e-series-water-mist-fire-extinguishers/ The UltraFire dry water mist extinguishers can be used on virtually all types of fire and if used on an actual fire they de-ionised water evaporated completely, leaving no residue whatsoever. Hope this helps. Shawn Quote
AnthonyB Posted June 19, 2017 Report Posted June 19, 2017 Water mist is best if you can afford it, an ABF rated Wet Chemical comes a close second. Quote
