Maximum number of people in a space
Guest ElizabethKB
I run a recreation area (for card players) in a modern building
- it is on the first floor.
- We have double fire doors 132 mm wide to the play area
- there is a small straight, lit corridor 145 mm wide
- a flight of 22 steps 112 wide to the glass external door
How many people can I have in this recreation area? This is a daytime activity (no one sleeps here!)
Thank you for your advice
I am assuming you have only one door from the playroom, the double fire doors 132 mm wide, this means you will be limited to a maximum of 60 people depending on the size of the room.
You have not indicated any travel distances, is the corridor a protected route and what the building is used for, which can affect the situation.
  • 1 month later...
First of all I think Elizabeth meant 132 cm not MM and a corridor of 145 cm, the doors will be inward opening doors, there was no calculation, if you read the guidance you will find a room with inward opening doors is limited to less than sixty persons.
