Guest DavidSmit
In a domestic property, is a steel chimney from a gas fired AGA considered safe and legal if it paces through a wardrobe on an upper floor before exhausting through the roof?
It should have been installed by a corgi register fitter in accordance with the Gas Regulations and the Building Regulation - Approved Document J. I would suggest you check out page 24 and 25 http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADJ_2010.pdf it appears there is some anomalies. I am no expert on BR but it looks like it should have been enclosed as shown in Diagram 13, you need to take advice from Building Control.
