Guest charlierich
Hi , I wondered if there is a pamphlet regarding the regulations re fitting fire doors. We are converting a loft in an old house .
1) do we have to fit imtumecent seals, if we have a ready made fire door?
2) if we fit the seals to excisting doors does that make them fire proof to standard?
3) do we have to do anything else to the frames?
thanks for your time, I hope you can help us. charlie
What you are proposing will require Building Regulations approval and as the result it will be up to the building control officer what him/her will accept. I am assuming you are not fitting a certified fire door set therefore it is almost certain you will need intumescent seals and maybe smoke seals. As the result you will have a nominal fire door which is fully explained in http://www.firesafe.org.uk/fire-doors/ and for more information on intumescent seals try
http://www.ifsa.org.uk/guidance.html
Providing the frame has a 12mm rebate and the the fire door is well fitted, then it shouldn't be necessary to do anything to the frame.
Guest Charlie
Sorry, Tom, what do you mean with the frame having a 12mm rebate?
Charlie
When you close a door it closes against a stop to prevent the door continuing through the frame. On most doors this stop is usually 12mm deep providing it it isn't a double swing door and this 12mm stop is known as the rebate. Many moons ago this rebate was increased to 25mm on fire doors but since the introduction of intumescent strips 12mm is adequate.
Guest mattCharl
Hi Tom
Thank you so much for your time , you managed to answer my question. We are fitting a certified fire door and you explained with that i don't need a frame seal. Thanks .
Is there a way of making an ordinary door up to fire door standard as the building regs people have asked /told us now we have to make the landing doors now to fire standard, they are unusually small as doors and finding them as certified ready made ones has become hard . We could make the door frames larger(horrid) and obviously don't wish too.
Sorry to keep picking your brains.
cheers Charlie
  • 6 years later...
Guest Eddy Priest
Can you clad both sides of a normal door with pink fire retardant plaster board to make it 1/2 fire resistant ❓
Hi Eddie,
Fire performance products must be installed in accordance with supporting evidence from a fire test report or assessment. If you are proposing to over board a door to improve its fire separation performance make sure you refer to the product data sheets to check suitability of the board for that application. You will also find the above mentioned article, about upgrading doors, useful with regard to the numerous components of the door assembly that contribute to its fire and smoke separation performance.
  • 9 months later...
Having read all of the comments. i have got an FD30 door in the correct frame, with the certificate. however the gap at the bottom of the door is excessive. is there anything that i can put at the bottom of the door to lessen the gap and still meet the requirements?
  • 1 year later...
Guest alex griffiges
On 10/10/2011 at 21:41, Tom Sutton said:
Hi Charlie
Harry answered your question for me and having the frame makes it much more compliant.
hello tom i recently had a visit from the council licensing  to inspect the property for a licence .I rent out a two bedroomed mid traced house to a female couple.she inspected the place and said that i need a electrical fire alarm fitted ( 3 battery smoke alarms and a carbon monoxide fitted) 2 fire doors fitted to bedrooms and escape windows fitted to the bedrooms ....is there any advice from anybody????
