Guest Wozzer Posted May 14, 2017 Report Posted May 14, 2017 The company I work for have a magnetic lock system in place but these are not linked with the fire system so when the alarms go off the doors are still locked. Now some doors have a green release function but my problem is if we do have a fire and electrics go too the old mag bolts will still be in position and the exits will be locked. Are they breaking fire safety rules ? Quote
green-foam Posted May 15, 2017 Report Posted May 15, 2017 If they are "mag locks" similar to the picture, then these are what is known as fail safe devices. So if there is a power failure they "fail safe" (not fail secure) and can not hold the door locked in the event of a power failure. Quote
AnthonyB Posted May 15, 2017 Report Posted May 15, 2017 Electromagnetic locks should release on power failure (but many have back up power supplies to prevent this), via a fire alarm interface and by a green 'break glass' override (looks like a green version of a fire alarm call point, but is a double pole isolator to drop the power to the magnet). BS7273-4 is the relevant British Standard. Quote
Tom Sutton Posted May 15, 2017 Report Posted May 15, 2017 What type of mag locks are being used and are they on an escape route. Are they fail safe or are they fail secure. Is there a battery back-up and what is the method/device of access/egress. Quote
Guest Wood Posted February 5, 2019 Report Posted February 5, 2019 We have triple matlock applied and there still kicking the doors in any ideas Quote
Tom Sutton Posted February 6, 2019 Report Posted February 6, 2019 This is a security problem check it out with a security firm/forum and I am sure they will be able suggest suitable doors which will also meet fire safety standards. Quote
