Guest ChrisBann Posted May 10, 2017 Report Posted May 10, 2017 Hi, I am trying to find legal documentation on the rules and regulations with placing a stairs to a fire exit outside a building. Thanks Chris Quote
AnthonyB Posted May 11, 2017 Report Posted May 11, 2017 Contact your local Council Planning Department as there will be requirements with Planning Permission and Building Regulations. https://www.planningportal.co.uk/ Quote
Tom Sutton Posted May 12, 2017 Report Posted May 12, 2017 Although the approved documents do not include external staircase the Approved Documents especially ADM and ADK may still be appropriate and will at least provide you with some guidelines upon which you could base your detailed design. Also you should consider BS 5395-1:2010 and BS 8300. Quote
Guest Julie Posted October 21, 2021 Report Posted October 21, 2021 My neighbour has an outside fire escape which has patio doors to it.is this legal Quote
AnthonyB Posted October 22, 2021 Report Posted October 22, 2021 Why not? If it's the highest set of doors on the stair they don't need to be fire doors. Quote
