Guest Fireexitrunningman Posted March 31, 2017 Report Posted March 31, 2017 I know that some companies such as Jalite will make vinyl or plastic inserts for illuminated fire exit boxes so that you can replace the signage without having to replace the whole box, but I can't seem to find anywhere that sells plastic or vinyl inserts that have the version of the running man signage with the flames behind it like this: Is there anywhere willing to do this such as Jalite if I ask, or would I need to get an emergency bulkhead light like the one below an stick signage like that above onto it? Quote
AnthonyB Posted March 31, 2017 Report Posted March 31, 2017 Jactone will make to order, their ex stock overlays are only ISO ones. It's been decades since I've seen NHS Estates symbol overlays sold ex stock, might be easier to use a standard non illuminated sign with a EL fitting no more than 2m away. Quote
Tom Sutton Posted April 1, 2017 Report Posted April 1, 2017 Why do you need an illuminated exit sign assuming it is not a place of public entertainment, I see many that are just not required and it would be easier to use a standard exit sign with a EL fitting no more than 2m away? Quote
Guest Fireexitrunningman Posted April 1, 2017 Report Posted April 1, 2017 I need such a sign for a lecture theatre and a drama/dance studio at a college. Quote
Tom Sutton Posted April 1, 2017 Report Posted April 1, 2017 Point taken, you do need an illuminated exit signs so why not fit illuminated exit boxes with BS 5499 standard templates. Quote
AnthonyB Posted April 1, 2017 Report Posted April 1, 2017 If it's not a hospital there is no need to use the elusive NHS Estates Symbol and just get the more readily available ISO 7010 pictogram, loads of maintained exit boxes with this pictogram available (but check as some suppliers are still trying to offload fittings with the discredited EC pictogram) Quote
