Guest Matt Posted March 27, 2017 Report Posted March 27, 2017 I'm part of a local charity that has had a number of FD30 doors fitted to existing frames. I'm looking for clarification/guidance on the thickness of the door check stops. At current the carpenter has fitted 19mm thick kiln dried timber. I've seen reference to 25mm stops. I was hoping to find clarification on this subject? Thank you for your time. Regards Quote
AnthonyB Posted March 27, 2017 Report Posted March 27, 2017 25mm stops date back to the days before intumescent seals and smoke brushes existed and were a rudimentary way of forming a seal on a door - if your doors are correctly fitted with intumescent seals (and if on an escape route smoke brushes) the 25mm stop is not required and a 19mm stop should suffice. Quote
Guest Fire door rebate Posted January 4, 2020 Report Posted January 4, 2020 Is a 18 mm Mdf rebate ( slam strip ) sufficient on a new domestic fire door ? or is pine .this of course sjoupd be glued & pinned / screwed Quote
Neil ashdown Posted January 5, 2020 Report Posted January 5, 2020 The new fire door will come with installation instructions or a technical data sheet. That information document will state door frame and planted stop requirements. Quote
Guest Alec Jameson Posted April 5, 2023 Report Posted April 5, 2023 When would a frame with 25mm door stop need upgrading to include an intumescent strip if the the 25mm was a standard before? Quote
Neil Ashdown MAFDI Posted April 6, 2023 Report Posted April 6, 2023 Where the fire door is so critical to the fire strategy at the building that it is desirable to upgrade the fire performance of the door. Consider that all timber-based fire doors have had intumescent seals for around the past 30 years now. So why wouldn't you fit them to a fire door? Quote
