Guest Keith Grimshaw Posted November 19, 2016 Report Share Posted November 19, 2016 can you still buy smoke alarms without a flashing red led? Quote Link to comment Share on other sites More sharing options...
green-foam Posted November 20, 2016 Report Share Posted November 20, 2016 Not seen one, but why would you want one without? By way of the LED flashing indicates the device is powered, and so should work. Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted November 21, 2016 Report Share Posted November 21, 2016 Only a grade F smoke alarm will not have a LED all mains fed smoke alarms will, as indicated by green-foam above, also the Grade D, mains fed smoke alarms are the recommended ones. Quote Link to comment Share on other sites More sharing options...
