Guest Keith Grimshaw Posted November 19, 2016 Report Posted November 19, 2016 can you still buy smoke alarms without a flashing red led? Quote
green-foam Posted November 20, 2016 Report Posted November 20, 2016 Not seen one, but why would you want one without? By way of the LED flashing indicates the device is powered, and so should work. Quote
Tom Sutton Posted November 21, 2016 Report Posted November 21, 2016 Only a grade F smoke alarm will not have a LED all mains fed smoke alarms will, as indicated by green-foam above, also the Grade D, mains fed smoke alarms are the recommended ones. Quote
