bob2813 Posted October 31, 2016 Report Posted October 31, 2016 7x Fire doors have just been installed in an HMO. The property is a 1930's Laing semi detached with dividing walls made of either early aerated block or single leaf brick. The new FD30s fire doors - being far heavier than those removed - now make quite a thud when they close - in fact the walls of the house seem to resonate constantly to the sound of closing doors throughout the day. If closers are adjusted to a less agressive closing and gentle speed - then they do not latch. Just wondered if others had experienced the same. Quote
Safelincs Posted November 1, 2016 Report Posted November 1, 2016 Hi Bob You need a fire door closer with adjustable latching action. You can then control the final closing action of the fire door (last 10-15 degrees of movement) rather than slamming the fire door all the way. A recommendation would be the GEZE TS1500 Harry Quote
