Guest Amanda Posted September 13, 2022 Report Posted September 13, 2022 Hi there, looking for similar advice please! I have just bought a main door flat. It is on the ground floor. The main door leads directly outside. There is, however, another door that leads into a communal close used by other residents. The door is original Victorian with painted glass. I'd hate to have to remove this historic feature. Does it need to be a fire door? Is there any way around this? Thanks. Quote
AnthonyB Posted September 14, 2022 Report Posted September 14, 2022 Not needed to be a fire door unless they have to pass directly past the door as their only means of escape. Quote
Guest Amanda Posted October 8, 2022 Report Posted October 8, 2022 I live in a maisonette. The front entrance a upvc door is a shared door with only 1 ground floor neighbour, and we both enter into our shared porch. From there I pass by my ground neighbours fire door on the right side and at the end of the porch is my flat door to go upstairs. My neighbour below has also a back door and also a fire window in his livingroom. It is suggested I need replace my door and all glass above it. Why? But it does not affect my neighbour who would not pass by me. They would be in front of me, use the back door or their livingroom window. And likely the fire would not be going down my 30 steps! I also have a back door that takes me directly out the rear of the building down concrete steps. Is this right to force me to rip out the door and window. Quote
Guest James Whitmarsh Posted October 19, 2022 Report Posted October 19, 2022 We are permitted to replace a front door in a block of flats. The front door opens to a open air stair well. Does the front door need to be a fire door? Quote
AnthonyB Posted October 24, 2022 Report Posted October 24, 2022 Is it the only stair or would the floors above have access to a second stair? Quote
Guest Second fire exit Posted March 30, 2023 Report Posted March 30, 2023 Hello, we are buying a 2 floors (ground floor and 1st floor) maisonette which is share owned with another person. There are 2 separate entrance, we enter directly form the ground floor and the other owner front he first floor, we do not share an entrance halloway. It results that based on current Building Regs the flat doesn’t comply in terms of means-of-escape because It should have a second exit, on the Upper Grd floor, but there is no space as we would need to get the upstairs flat to agree an exit door into the Hallway (now part of their house). the ground floor has a garden and first floor a terrace and the window facing the street. Is there any other solution to replace the second exit door? martina Quote
AnthonyB Posted April 3, 2023 Report Posted April 3, 2023 Building Regulations aren't retrospective so if an existing situation it isn't an issue unless some alterations are being carried out that would make the premises subject to the latest edition. Sprinklers and protected stairways are sometimes accepted as an alternative. Quote
Guest Guest KM Posted June 12, 2024 Report Posted June 12, 2024 I live in a purpose built 1st floor maisonette with only two stories to the building. My front door opens on to external concrete stairs straight on to the garden I don’t have to pass the kitchen to exit the property do I need any fire doors? Quote
AnthonyB Posted June 17, 2024 Report Posted June 17, 2024 Doesn't sound like it, certainly not the front door. Quote
AnthonyW Posted November 22, 2024 Report Posted November 22, 2024 Hi. We have a 2nd storey 1985 built flat on the second story of a large block. The access to the flat is from an external circular walkway (which is on the inside of the large building), which leads to a lift exit on one side of the walkway, and an external staircase next on the other side, next to the flat. There is an old fire door (but with no self-closing mechanism).There are old fire doors to the internal doors of the flat but these do not have 2-4mm gaps etc. What are the fire requirements please, eg do we need new self closing front door, + internal door with 2-4mm gaps etc? MTIA Quote
