Dean Posted October 22, 2016 Report Posted October 22, 2016 I am looking for some help understanding fire protection requirements for a communal meter cupboard located in the property in which I live. The property consists of: 5 self contained flats over 5 floors of a converted period building 4 of which share a communal main entrance and hallway (including staircase) leading to the individual flat entrances, this staircase forms the only escape route for these 4 flats 1 flat has its own external main entrance (basement flat) and does not share any of the communal space, the flat opens directly to the outside space The flats are a mixture of owner occupied and rented A fire safety inspection was undertaken. The inspector identified the property as an HMO which will influence fire protection requirements. The following requests were made as part of the report: Meter cupboard to be bought up to BS 476 standards The meter cupboard requirements are very light on detail, only mentioning the BS 476 standards. I need to ensure work undertaken provides the necessary protection. I have completed some research online and in particular within this useful forum. Posts I believe to be relevant are: It seems as though many factors may influence the requirements: Age of the premises Condition of the property Evacuation strategy for the building Combustibles in the vicinity Any additional risks posed by other equipment in addition to the meters Guidance that was contemporary at the time the premises was altered The internal construction of the cupboard The location of the cupboard under the stairs which form the only escape route for flats above All of the above points will influence the requirements; I understand that without visiting the property and viewing the cupboard it would be difficult to specify exactly what is required. However, would anyone be able to provide a basic overview of: What is required as a minimum, based on the facts outlined above Additional requirements which will need to be investigated, based on the specific construction/location/condition etc. of the current cupboard Any help would be gratefully received. Thanks, Dean Quote
AnthonyB Posted October 24, 2016 Report Posted October 24, 2016 It's not just the door that needs to be a fire door - if the stair is wooden it needs underdrawing with a suitable layer of fire boarding (usually plasterboard of at least 12.5mm or glass reinforced gyspum sheeting of at least 10mm) suitably secured to a metal or wooden stud with edges sealed with fire mastic Quote
Dean Posted February 28, 2017 Author Report Posted February 28, 2017 Thank you for your response, Anthony. It has been a while since I posted this question and some work has been completed on the communal meter cupboard in our building to improve the compartmentalisation. Installation of 30m fire resistant door Door edge lined with intumescent strip Door fitted with a key operated lock The new door does not have a self-closing device but does have a lock which ensures the cupboard is closed at all times. Does a communal meter cupboard require a self closer or should a lock operated door suffice for compliance with safety regulations? Inside the cupboard a partition wall exists but needs to be repaired, based on your advice I am recommending the installation of Gypsum Glasroc board (glass reinforced) on to the existing wooden stud, example: http://www.british-gypsum.com/products/glasroc-f-firecase I will also recommend the installation of the same Gypsum Glasroc board to the ceiling of the cupboard. Combined, the new door, lining of the ceiling and the upgrading of the partition wall will compartmentalise the cupboard, providing fire resistance from the wooden stairway construction above. Behind the partition there is a power supply to which we need access for servicing. I am recommending an aperture to be cut in the partition and the installation of a fire rated access panel, example: http://www.jupiterblue.co.uk/access-panels-and-access-hatches-c1/plasterboard-c41/bfs-plast-beaded-frame-access-panel-with-plaster-door-p115 Does this seem to be a sound approach, can you see any faults with my design? At the edges/joins of the partition, fire rated panel and ceiling lining I assume fire resistant sealant should be used, is this correct? Thank you in advance, the advice received on this forum to date has been invaluable. Quote
AnthonyB Posted March 1, 2017 Report Posted March 1, 2017 Cupboards and the like, being infrequently accessed, do not require self closers if they are kept locked shut and signed as shut. Edges should be sealed with intumescent mastic/putty. All looks good from here! Quote
Guest Adam Posted January 24, 2018 Report Posted January 24, 2018 Dont Safeclinics do a 60min plasterboard paint that would do the job ???? Quote
Safelincs Posted January 24, 2018 Report Posted January 24, 2018 Hi Adam I guess you meant Safelincs. I wish we could help with this but sorry we can't. A great product idea, though. Harry Quote
green-foam Posted January 25, 2018 Report Posted January 25, 2018 Thing is..............the job has probably been done by now as it was asked back in 2016 Quote
Guest rogerh Posted January 31, 2018 Report Posted January 31, 2018 On 22/10/2016 at 11:47, Dean said: The inspector identified the property as an HMO which will influence fire protection requirements. Why? If the flats are as described, i.e. all self-contained, it's not an HMO. The tenants would need to "share toilet, bathroom or kitchen facilities with other tenants". https://www.gov.uk/private-renting/houses-in-multiple-occupation Quote
Tom Sutton Posted February 2, 2018 Report Posted February 2, 2018 I fully agree roger but if the meter cupboard is in the communal area it will still need to meet a full 30 minutes fire resistance, so all above still applies. Quote
Guest Sam Posted October 4, 2018 Report Posted October 4, 2018 Hello everyone, I was wondering if it is possible to paint the understairs cupboard with a fire retardant material instead of boarding? Quote
AnthonyB Posted October 4, 2018 Report Posted October 4, 2018 https://envirograf.com/ do such products, it depends on the surface you are treating and the performance needed as to if there is a viable product. Quote
Guest Moz Posted February 24, 2020 Report Posted February 24, 2020 On 31/01/2018 at 21:56, Guest rogerh said: Why? If the flats are as described, i.e. all self-contained, it's not an HMO. The tenants would need to "share toilet, bathroom or kitchen facilities with other tenants". https://www.gov.uk/private-renting/houses-in-multiple-occupation It would likely be a s257 HMO. Quote
Tom Sutton Posted February 25, 2020 Report Posted February 25, 2020 You would need to know more information like if it conformed to the building regulations or when it was converted. Quote
Guest Sunny D Posted July 23, 2020 Report Posted July 23, 2020 Please can I ask where you got the cupboard door from? I was wondering if I’d just have to buy a door and cut to size, but then though that would diminish the effects of it. I’m also wondering that if the original cupboard door was passed by building regs, then why does it need changing now? This has never come up over the past 40 years and it’s a purpose built building with 8 flats. Thanks for any help. Quote
Guest Sunny D Posted July 23, 2020 Report Posted July 23, 2020 Any help on where I can purchase a small fire door for a cupboard under the stairs please? The latest inspector has asked for this to be changed even though it’s the original door from when the flats were built, early 1980’s, 8 studio flats over two floors in a purpose built development. I’m struggling to find a suitable sized door. Thanks. Quote
Tom Sutton Posted July 28, 2020 Report Posted July 28, 2020 Is the fire inspector you speak of a fire and rescue officer or a person conducting a fire risk assessment. Quote
Guest AA1 Posted April 15, 2021 Report Posted April 15, 2021 On 23/07/2020 at 09:09, Guest Sunny D said: Any help on where I can purchase a small fire door for a cupboard under the stairs please? The latest inspector has asked for this to be changed even though it’s the original door from when the flats were built, early 1980’s, 8 studio flats over two floors in a purpose built development. I’m struggling to find a suitable sized door. Thanks. Buy a fire door blank and cut to size then edge with hardwood lipping round the door. Fire rated hinges and intumescent wraps round lock will do the trick. You will also need a new frame and fit intumescent smoke brush seals and seal gaps between wall and frame with intumescent mastic Quote
AnthonyB Posted April 16, 2021 Report Posted April 16, 2021 Be aware that cutting down a fire door outside the parameters allowed by the manufacturer will invalidate the doors certification and more importantly lead to premature failure. Quote
Guest Fire rated meter overbox Posted November 5 Report Posted November 5 Please could you advise on where I could buy reliable affordable 30 minutes fire rated overboxes for electric meters? Quote
AnthonyB Posted November 6 Report Posted November 6 On 05/11/2024 at 10:01, Guest Fire rated meter overbox said: Please could you advise on where I could buy reliable affordable 30 minutes fire rated overboxes for electric meters? https://envirograf.com/product-category/electrical-and-plumbing/ Quote
