Ei141 beeping
Guest Steven Tschache
My Ei141RC blips every 2-3 seconds. Nothing in the manual states what could be the problem witha short interval like that.
Mains supply is good (green light). Changed battery, still Blips. Replaced with brand new unit, same happens again as soon as I slot it in.
Please note, it's not the Allarm-Sound like long Beeps, but rather just a short Blip.
Hi Steven
As you have changed the Alarm it sound like there’s an issue with the cable or power supply. Was the Base plate changed as well? I have attached a couple Of Technical Bulletin which may help
If nothing else helps, please ring Tel: 01691 664100
Harry
No.19e Power supplies for Grade D alarms - IEE Regulations.pdf
No.21a Wiring Smoke Heat Alarms - Alternative Energy Sources.pdf
No, I haven't changed the Base-Plate. Nothing has changed there and as I mentioned, the green (power) light is constant when I slide the alarm in. I have also measured the voltage on the Base-Plate, and all OK at 248V.
