Fire Exit Signage
Good Morning,
I am happy i all my Fire Exits are correctly located, the right type of door and all have the right amount of space available for the safe egress of all employees.
My Problem is, exactly what signs/notices should i have on both sides of the door?
On most of them i have the dual sign 'Fire Exit, Keep Clear'. Do i need this on both sides of the door/exit?
I am assuming you are talking about a final exit door and the 'Fire Exit, Keep Clear' should be located on the outside of the door to prevent people accidentally blocking the exit door. On the inside you should have standard 'Fire Exit sign and a separate keep clear sign only if there is a chance of the door being blocked also a 'Push Bar To Open' if you have an emergency push bar.
