Guest Clark Posted July 11, 2016 Report Posted July 11, 2016 Dear All, Can I finish a fire rated timber door leaf with a stainless steel finish? Does this affect the fire rating? Thank you. Quote
Tom Sutton Posted July 12, 2016 Report Posted July 12, 2016 In my opinion it is more likely to increase the fire resistance dependent on how the stainless steel is fitted to the door and on which side the risk or low risk side? It would also be important that it didn't interfere with the seals both intumescent/cold smoke. Quote
