Guest EdwardWhe Posted June 8, 2016 Report Posted June 8, 2016 The managing agents in the block where I live are using their own in-house work force to do extensive fire stopping. Do the regulations require independent certification of the finished fire stopping? What are the labelling requirements? Many thanks, Edward Quote
Tom Sutton Posted June 8, 2016 Report Posted June 8, 2016 There is no requirement for independent certification of fire stopping and no labelling requirements. When the work is complete and if subject to building regulations the authorise inspector or the building control officer will issue a completion certificate. Also on completion the premises will be subject to the FRA being reviewed and the FR assessor will check the work and give his/her approval. Quote
AnthonyB Posted June 8, 2016 Report Posted June 8, 2016 Unfortunately a completion certificate has no bearing as to whether the physical works on site are suitable. Third party certification & marking is not required, but desirable. If suitably qualified/experienced a fire risk assessor can assess suitability. It's important the correct materials are used, the non specialist contractors have a tendency to fill all & sundry gaps with fire retardant foam where in reality only intumescent collars, mastic, ablative batt and other materials would be effective. Quote
Tom Sutton Posted June 14, 2016 Report Posted June 14, 2016 If a completion certificate has no bearing as to whether the physical works on site are suitable what is its purpose. I understand it is proof that the building work has been carried out in accordance with Building Regulations and therefore, as far as can be reasonably determined, is built to certain standards that would include the physical works? Quote
AnthonyB Posted June 14, 2016 Report Posted June 14, 2016 Believe me I have seen so much snagging and corner cutting so consistently on new builds around the country that it seems the certification is based more on the design plans and that there is little physical inspection anymore! Quote
Guest Jay Posted October 24, 2019 Report Posted October 24, 2019 Hi, is 3rd party accreditation Mandatory for Building control under document B ? or is it a tool for giving confidence to the person sighing off the building ? Thanks J Quote
Tom Sutton Posted October 25, 2019 Report Posted October 25, 2019 I am not aware that BCO/AI have a 3rd party accreditation, they have to qualify for their role and that gives them the power to sign off work, subject to building regs. Quote
Guest Andy B Posted February 10, 2020 Report Posted February 10, 2020 I am actually astounded that there is not a requirement for certification for fire stopping. We are a small internals company who have operatives who are Firas trained but I’ve always maintained if the company are not registered we can’t give the correct certs and can’t carry out the works. Can anyone clarify please Quote
Guest Joepaul Posted March 5, 2022 Report Posted March 5, 2022 Hi Ive been asked to carry out fire stopping has part of a partition package in a office refurb, What quilifations do i need to have to carry out this work has company owner, i can have my fixers sit exams to quilfy them to carry out the work, Quote
Guest 1234 Posted January 27 Report Posted January 27 I work for a fire stopping company not qualified can I mark up my own work or should this be done by someone who is qualified Quote
Fire Safety Specialists Posted February 3 Report Posted February 3 On 27/01/2025 at 10:40, Guest 1234 said: I work for a fire stopping company not qualified can I mark up my own work or should this be done by someone who is qualified AFAIK there is no requirement for qualification and certifying a job means nothing, legally. It depends more on the products you are using and the exact methodology for applying them according to the manufacturers instructions. Quote
