Guest Impressed peruser Posted August 31, 2016 Report Share Posted August 31, 2016 Wow, Those are some impressively detailed responses Mr Sutton, you are a credit to this site. Thank you for the info. Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted September 2, 2016 Report Share Posted September 2, 2016 Thanks not bad for an old git but I do no more than read the guidance and try to interpret. Quote Link to comment Share on other sites More sharing options...
Guest Fire label on each item? Posted February 4, 2017 Report Share Posted February 4, 2017 Hi, Looking to pass on a fabric 3 seater, 2 seater and a chair to a charity (British Heart Foundation). Looking at the sofas which were all bought as a set from a retailer more than 10 years ago, only the single chair has a fire label on it. The 2 and 3 seater just have the care instructions with batch number etc on it. Should each item have it's own label or is it okay if they are part of the same batch? Thanks, Quote Link to comment Share on other sites More sharing options...
AnthonyB Posted February 4, 2017 Report Share Posted February 4, 2017 Legally each item should retain it's permanent label Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted February 5, 2017 Report Share Posted February 5, 2017 What does the fire label and care label say, its shape and what are they made from? Quote Link to comment Share on other sites More sharing options...
Guest Karen Posted April 11, 2017 Report Share Posted April 11, 2017 Hi there- we want to give our sofa away to charity - it's about 15 years old and we still have the labels required- However they have come away from the staple so detached are these acceptable to give away? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted April 12, 2017 Report Share Posted April 12, 2017 If you are sure they are the original labels, just staple them back, although the regulations say they should be permanently fixed, I have seen them stapled, but how permanent should permanently be? Quote Link to comment Share on other sites More sharing options...
Guest Barbara Posted April 24, 2017 Report Share Posted April 24, 2017 Hi Tom, I have a lovely danish 1960s sofa (ercol style) that I would like to use in a rental property. It has a polished wooden frame and the cushions, back and armrests are all upholstered in thick leather. The cushion filling is goose feather. Would the leather be regarded as fire retardant / fire resistant? Many thanks Quote Link to comment Share on other sites More sharing options...
Guest Kim w Posted April 25, 2017 Report Share Posted April 25, 2017 Hi, I have read that fire retardant fabric can lose its effectiveness over time, from normal wear and even from been cleaned. So if I buy a second hand sofa which has the correct label attached, How do i know the fire retardant material is still effective. Would you recommend getting a flame retardant coating re-appliwd? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted April 27, 2017 Report Share Posted April 27, 2017 The problem is the only way to see if a material has lost its fire retardant properties would be to test it and that would destroy the piece of furniture. The Fire safety of furniture and furnishings in the home - A Guide to the UK Regulations only deal with the upholstered furniture at the time of manufacture, importing, resale or re-upholstery and to check the documentation for a further five years. Providing the sofa has the appropriate permanent label attached you are legally correct but if you need reassurance then have the flame retardant coating re-applied. Quote Link to comment Share on other sites More sharing options...
Guest Testing Fire regulations ! Posted August 20, 2017 Report Share Posted August 20, 2017 Hi Tom Firstly, thank you for taking time to respond to all the questions ! We have a sofa (15 years old!!) in our rented out house. It has no label that we can find, which is strange as it is a Collins and Hayes sofa , and I just think it somehow came off. The problem, that we have is that if we remove the sofa, we need to get fitters to remove balcony doors etc. I have no doubt that it is compliant but just cannot prove it ! There may be labels on the cushions but does there need to be one on the frame itself ? If we have them on cushions, can we just spray the frame with fire retardant? Are there companies that "test"? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted September 5, 2017 Report Share Posted September 5, 2017 There needs to be a permanent label on each separate item of the sofa and if one has come loose then there isn't much you can do about it especially if it it 15 years old. Records only have to be held for five years, so there is no chance of getting a copy, but if you are happy with it then the only problem to arise, is if you decide to sell it or give it to a charity. Quote Link to comment Share on other sites More sharing options...
Guest Lynn P Posted January 24, 2019 Report Share Posted January 24, 2019 Hi. I have read the various replies above. I have a 2 seater settee,which has been re upholstered and the labels presumably been covered up. I want to give this away , rather than take it to the tip, as it still has a lot of use in it. Am I ok to give it away to general public? I know charities won't take it. Lynn Prime Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted January 26, 2019 Report Share Posted January 26, 2019 In my opinion because it is not for sale and the other person is prepared to accept it, then it is not subject to the regulations but I think you have a moral responsibility to make this person full aware that there is no proof that the settee would be safe in fire situation. Quote Link to comment Share on other sites More sharing options...
Guest Louise Posted March 4, 2019 Report Share Posted March 4, 2019 Hi Tom I have just read your answer to a question about second hand furniture and safety regs Could you advise on my scenario please: I run a mental health support group and rent a building from MOD and they have requested I have all the soft furnishings we have to have fire retardant labels We were given this furniture for free as donations and just wondered where we stand with this situation and if we do have to have them fireproofed how would we go about it Thanks Louise Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted March 6, 2019 Report Share Posted March 6, 2019 I suspect this is all about The Regulatory Reform (Fire Safety) Order 2005 which requires the Responsible Person to conduct a Fire Risk Assessment under article 9 and part of it is reducing or eliminating fire risk to prevent fire starting or spreading. Upholstered furniture is a fire risk and to reduce that risk appling the Furniture-and-furnishings-fire-safety-regulations-19881989-and-1993/ would achieve that and the label would prove it meets the required standard. You could apply Fire safety of furniture and furnishings in the contract and non-domestic sectors but you would still need the label, just a different label to prove it complies. Quote Link to comment Share on other sites More sharing options...
Guest Nayya Posted March 29, 2019 Report Share Posted March 29, 2019 Why are flam retardants even allow3d when its been proved they are toxic to us?! Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted March 29, 2019 Report Share Posted March 29, 2019 Check out http://www.toxicsofa.com/ Quote Link to comment Share on other sites More sharing options...
Guest Marg Posted September 2, 2019 Report Share Posted September 2, 2019 Hi I have a suite that is about 4years old and did have a fire notice when I bought it but it must have came off ,I am wanting to donate this to the Heart Foundation can you tell me will they accept it Quote Link to comment Share on other sites More sharing options...
green-foam Posted September 2, 2019 Report Share Posted September 2, 2019 Why not phone them and ask will they accept it? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted September 6, 2019 Report Share Posted September 6, 2019 The notice that fell off, was it a display label or a permanent label. Check out Fire safety of furniture and furnishings in the home A Guide to the UK Regulations FIRA Quote Link to comment Share on other sites More sharing options...
Guest Barbara Barnes Posted October 25, 2021 Report Share Posted October 25, 2021 On 29/11/2011 at 15:16, Guest Hannah said: Just to double check. We are a chairty who gives furniture to people in need free of charge. We have a three piece suite where the sofa does not have a fire label but the matching chair does. Are we ok to give the sofa away with the chair (to the same person) even if it doesn't have a fire lable? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted October 26, 2021 Report Share Posted October 26, 2021 Strictly speaking if the sofa does not have a fire label then it is illegal and should not be sold, but I would suggest you examine it very carefully, as they fix these permanent labels in the strangest of places. Quote Link to comment Share on other sites More sharing options...
Guest Jenny Webb Posted June 11, 2022 Report Share Posted June 11, 2022 Hello everyone, Have found this conversation very interesting as am in the position of wanting to rent out my house for 2 years but 2 leather sofas, a matching chair & a double mattress are all devoid of the necessary fire labels (all made post 1988)...and the agent said they cannot stay in the house. Storage over 2 years would cost more than the items are worth but I don't want to get rid of them. Does anyone know if I can get these inspected by someone in an official/legal capacity who would then be able to issue a retrospective fire safety label? Quote Link to comment Share on other sites More sharing options...
AnthonyB Posted June 22, 2022 Report Share Posted June 22, 2022 Unlikely, they'd potentially have to destructively test it. The only other option is certified treatment https://www.flameprotectuk.com/?gclid=CjwKCAjw-8qVBhANEiwAfjXLrp2JunzO-vJ6PBncr5P5Bhi-rAt8S2LBm8HLx1tCgQq3qNXDNAspARoCh2oQAvD_BwE Quote Link to comment Share on other sites More sharing options...
