Guest sandyfra Posted April 1, 2016 Report Posted April 1, 2016 I would like to know what type of door furniture is suitable for an inward opening final fire door from a small office, about 6 people, thanks Quote
Tom Sutton Posted April 1, 2016 Report Posted April 1, 2016 Depends if you do not require security from people entering the office from outside. If people can enter from the outside then a standard single action lever door handle could be used in combination with a deadlock to be used when the office is unoccupied, opened by the first person in, and closed last person leaving. I you require security from people entering the office then a rim lock with a single action lever type thumb screw combined with a dead lock for security when the office is unoccupied. You could use a deadlock with a thumb screw lever on the inside and key access from the outside specially designed for the purpose like the Marston 4K Escape Mortice Dead Door Lock. Finally you could use a magnetic lock but quite expensive it all depends what you want. Quote
