Do I need both fire door retainer and door closer?
Guest Louise
Guest Louise
I look forward to your response.
Do I need a fire door closure in addition to the retainer.
If I installed a fire door retainer, would this work on a door that doesn't stay open on it's own?
I have an indoor fire door within the office. It doesn't hold open on it's own.
A fire door has to be fitted with a door closer to ensure the fire door is in the closed position when a fire reaches it. If you need to keep a fire open then you can fit a fire door keep open device (retainer) which release the door when the fire alarm operates and the fire door closes as it should.
Check out http://www.firecode.org.uk/.
