Dimensions for external fire escape
Guest MikeMoor
Guest MikeMoor
I am trying to find the required dimensions for an external fire escape from a multi-storeyed house. Can you please advise? Building Regulations appear to deal with internal stairs and exits from a building.
Use Approved Document B volume 1 if it is a single dwelling house and use volume 2 if it is a flat
External fire escapes are staircases therefore use the same guidance as for internal staircases, use Approved Document K, Approved Document M and Approved Document B, for its design. However there are additional requirements, inspecting, testing and protection from the elements.
Check out http://www.designingbuildings.co.uk/wiki/Stairs
http://www.planningportal.gov.uk/buildingregulations/approveddocuments/
Guest beachguide
Our house is one converted into five flats with an external fire escape. Approved Document K appears to require ALL staircases with open risers to have a vertical gap of less than 100mm. Is this correct?
Guest beachguide
This is a new fire escape.
You should check it out with Building Control but it appears there should be no gaps for flats and you should not be able to pass a 100mm sphere between the open steps for dwellings.
Check out  https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/443181/BR_PDF_AD_K_2013.pdf page 6
  • 4 years later...
Guest Hi, I need a
Hi, I need a walkway outside the first floor of a commercial building for emergency exits for 3 flats. Do you think I need planning permission for the walkways? Planners have no idea and want me to apply anyway but can't say if I do need one!
Many thanks
